3D Printing Hinges
Frasian
(@frasian)
3D Printing Hinges
Hi everyone! Thanks for helping!
So, I am trying to print something with a 'print in place' hinge. It's not a big hinge, but it's also not a small hinge. I find that whenever I am done printing it, it doesn't actually close. There is something that is keeping it open. Any suggestions? I added a images of what sizes I am using for inner/outer diameter of the hinges, what the part looks like etc. I have tried making the hinge dimensions smaller, larger, everything I can think of.  The hinge seems to print fine, but when trying to close it, it does not. You can see what it does in the last image. PLEASE HELP!! Have been trying to solve this forever.
Finished Printing:
Napsal : 08/05/2022 11:36 am
BrassEm
(@brassem)
RE: 3D Printing Hinges
Try reducing your plate thickness.
Napsal : 08/05/2022 12:42 pm
BrassEm
(@brassem)
Napsal : 08/05/2022 12:45 pm
Move one of the top faces back 0.5 mm.
Napsal : 08/05/2022 5:01 pm
Frasian
(@frasian)
Hi guys!
Thank you for the advice. That worked! Any reason why that is?
Napsal : 08/05/2022 7:48 pm
BrassEm
(@brassem)
Hope this explains it. (Click on the pic to see the whole diagram.)
This post was modified před 4 years by BrassEm
Napsal : 08/05/2022 10:08 pm
Frasian
(@frasian)
Thanks for taking the time to make that diagram! It makes total sense.
This post was modified před 4 years by Frasian
Napsal : 08/05/2022 11:55 pm
@brassem explained it well. I would just add that even if you have what he/she calls "perfect alignment" you may still run into issues because of the intrinsic imperfections of FDM 3D printing. Different printers have different tolerances, so I always add in a bit of extra clearance.
Napsal : 09/05/2022 10:55 pm
1 lidem se líbí
thegamingbanana
(@thegamingbanana)
Hello, I am currently trying to print a similar hinge, however my parts are continuously printing fused together and do not create a functional hinge. What were the sizing of your parts, and the gap in between the two parts for the hinge? Also, did you optimize your printer in any way to get a more functional print? Thanks a lot!
Napsal : 21/01/2025 10:07 pm
Artur5
(@artur5)
I don’t like hinges made on a single part design. I prefer to split the model in two parts, later attached by a metal screw. The resulting hinge is stronger and easier to print.
See the stl file attached below. Those are for the front doors of an enclosure. At left the single part version and at right the version of two parts. On that one you use a M3x35 or M3x40 screw that threads directly onto the plastic and you’re done. Alternatively you can use brass inserts to screw the bolt.
This post was modified před 10 months by Artur5
Napsal : 23/01/2025 6:52 pm
