					                		Z Axis calibration failed at the top - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-axis-calibration-failed-at-the-top/</link>
                <lastBuildDate>Tue, 09 Jun 2026 15:22:24 +0000</lastBuildDate>
                        <title>RE: Z Axis calibration failed at the top</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-axis-calibration-failed-at-the-top/#post-168781</link>
                        <pubDate>Mon, 14 Oct 2019 16:23:07 +0000</pubDate>
                        <description><![CDATA[@charles-h13Thanks for that link. I think I might have it solved. The pinda is going on and off from the cable flexing. Going to unwrap and see if its repairable. If not, guess I&#039;ll order a ...]]></description>
                        <content:encoded><![CDATA[<p>@charles-h13</p><p>Thanks for that link. I think I might have it solved. The pinda is going on and off from the cable flexing. Going to unwrap and see if its repairable. If not, guess I'll order a new one.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>CWCDesigns</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-axis-calibration-failed-at-the-top/#post-168781</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-axis-calibration-failed-at-the-top/#post-168764</link>
                        <pubDate>Mon, 14 Oct 2019 15:31:25 +0000</pubDate>
                        <description><![CDATA[?  No idea.]]></description>
                        <content:encoded><![CDATA[<p>?  No idea.  </p><p> </p><p>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-calibration-failure/</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-axis-calibration-failed-at-the-top/#post-168764</guid>
                        <title>Z Axis calibration failed at the top</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-axis-calibration-failed-at-the-top/#post-168754</link>
                        <pubDate>Mon, 14 Oct 2019 14:12:40 +0000</pubDate>
                        <description><![CDATA[After the Z axis gets to the very top and asks about the steel sheet and clean nozzle the moment it starts to go down I get the Calibration Failed! after it has only gone down maybe 2mm. I&#039;v...]]></description>
                        <content:encoded><![CDATA[<p>After the Z axis gets to the very top and asks about the steel sheet and clean nozzle the moment it starts to go down I get the Calibration Failed! after it has only gone down maybe 2mm. I've been using this printer for a little over a year and a half with zero issues. This just started happening 2 days ago. Thoughts?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/z-axis-calibration-failed-at-the-top/#post-168754</guid>
