Y Crash detected 12 times during single print :O
MartinD
(@martind)
I tried to print in color with MMU2s, and I got Y crash 12 times on single print.
The Y movement is very smooth, lubricated, no any issues when moving it manually, nothing is blocking in path.
Belt test Y is 290.
What could cause these crashes, it is pretty annoying because after cras, even if I choose to resume print everything is kind of shifted.
Postato : 14/08/2020 5:33 am
Andy2232
(@andy2232)
RE: Y Crash detected 12 times during single print :O
I seem to have similar issues (see my post yesterday:  Permanent layer shifts on Y-axis, no remedy working)
Do you have these issues also without MMU2S?
Does the print crash completely or are your layers just shifted in y-direction?
My belt Y was also about 280-290. I tightened it yesterday after my post to about 250, but that did not fix it.
Do you hear some strange rumble when the crash occurs?
Postato : 14/08/2020 11:08 am
MartinD
(@martind)
Posted by: @andy2232
Nope no rumble, just crash occured, I checket the printed surface if there are any issues, nothing. it is entirely flat.
I got message - crash detected, I select resume print, then layer is shifted.
I tried to print with lower speed, I got no crash at 85% of speed. I cant test it without MMU2S as the model is multicolored.
Try to lower speed as I did, maybe that helps, but the issue is not solved only avoided.
Postato : 14/08/2020 11:41 am
