Y-axis having problems
Missbalrock
(@missbalrock)
Hello 🤗
I'm having trouble with my y-axis. I have tried putting my printer on a flat surface to make sure it's frame is not warped (it's not) and then loosened all the small screws and tightened them again one at a time.
All this happened because I tightened the screws to the rods and the belt only in the front.
There were no problems before this and I just wanted to tighten a loose screw. 😅
Posted : 16/06/2025 9:27 am
Robin_13
(@robin_13)
RE: Y-axis having problems
Having a problem on the Y-axis is a vague issue.  What are the details?  Not calibrating?  Not moving?
When I have had problems, I always turn to the assembly manual to reset the various parts.
Posted : 18/06/2025 4:28 pm
