Y Axis crash detection and skipping on MK3
Matt
 Matt
(@matt-11)
Hi everyone. Over the past several weeks my MK3 has started to skip on the y-axis, it started on a complex print, so I inspected the printer and noticed that the front idler was loose with about a 2 to 3 mm gap between it and the frame. I tighten it up and started printing again and it seemed alright till about 5 days ago. Once another layer shift occurred on the y-axis I did some reading and it seemed like there was some issue and the common advice was to disable crash detection, so for a test I did and it seemed as though the issue might be resolved. It was not, so I started to do some digging and came across a support article that mentioned the belt tension and how to check it after a self test in the menu. I ran self test and everything past, but the y axis was really close to 280 so I tightened it up by a tooth and ran self test again, it then registered 240. However, problem not solved. Today I had 2 small (different prints) shift again. So, I turned on crash detection again and printed the whistle on the sd card. The printer detected 3 crashes while printing the whistle and reentered itself. I have checked for debris, the y-axis does not have any obstruction, the belt is tensioned to spec, the rails are lubricated and everything moves freely, I have checked to make sure everything is tight, including the stepper gear and bracket, idler, frame, a basic once over of the entire printer. But I cannot print a whistle without running into several y-axis crashes. I have also updated firmware to 3.5.1. I am not sure what do at this point. I have a MK2.5 I can use, but it sees more limited use since we received the mk3 about 4 months ago. Oh, I should add I purchased the printer pre-built, but am very familiar with its workings. Any suggestions are much appreciated.
Veröffentlicht : 14/01/2019 8:45 am
Re: Y Axis crash detection and skipping on MK3
when the printer is at rest, does the y axis move smoothly backward and forward?
if not, problems could be
motor pulley rubbing on motor case,
idler pulley mounting bolt over tight causing friction,#
idler bearing failing
cabling snagging
linear bearings needing lubrication
linear bearings failing
or something similar
Veröffentlicht : 14/01/2019 9:09 am
Matt
 Matt
(@matt-11)
Joan, thank you so much for the response. I spent a few hours with chat support last night and made a little progress. We went through some of these things together. while taking some photos to send to support my bed skip a tooth on the retainer. I did a self test and the bet tension came back at 265, it was 240 previously. I tried to print the whistle again and it finished without any y-crashes. However today, we started a larger print and about 20% complete and it skipped again, it did not detect a y-axis crash and kept printing. Last night support suggested unplugging power panic and seeing if that helps. In the process I have done the following:
-make sure all components are tight.
-make sure all components move freely
-the bearing are lubricated and move freely
-make sure the gear scrub screws are tight
The idler seems to move smoothly, however I have not tried it under stress. So that will be next. I am thinking of back revving the firmware, has anyone ever done this?
Veröffentlicht : 15/01/2019 5:51 am
Bunny Science
(@bunny-science)
Testing the y-axis is easier if you isolate the components.
Release all tension on the y-belt and detach both ends of it from y-carriage. Remember which end goes into which slot of the belt holder.
Move carriage back and forth. There should be no binding anywhere along y-axis travel. If you detect binding, remove the heatbed to access the bearing mounts.
Slightly loosen the u-bolt nuts and test if that removes binding.
If loosening u-bolts helps, very gradually re-tighten the nuts until snug, but not causing any binding.
If loosening u-bolts helps does not help, suspect bad bearing or bearing needing cleaning/greasing. That means pull the rods and bearings.
Idler pulley check.
With y-carriage moved all the way rearward out of the way, manually check how freely the idler pulley moves with the belt.
Do so by holding two ends of belt in your hands and manually run the belt back and forth through idler pulley. You should practically zero friction.
If you detect friction or binding, check pulley mount and/or its bearing.
Veröffentlicht : 15/01/2019 7:40 am
Matt
 Matt
(@matt-11)
Here is an update on my y-axis skipping or layer shift. I took apart the y-axis assembly to make sure bearing and idler where are still alright. All was good however when I put it back together I found that the belt was running tight against one side fo the drive gear, I moved the gear out to better align, it still does not run completely center, but I move it a few mm's. I have now printed a handful of test prints, the last one was 7 hours long and it completed successfully. I am surprised that the little bit of drag caused such issues, but it does seem to now be printing without issue. Thank you everyone for your help.
Veröffentlicht : 19/01/2019 7:26 pm
Kazarenko
(@kazarenko)
RE: Y Axis crash detection and skipping on MK3
I had the same issue and tried lots of things. I had built the Mk3s and printed fine with it for 10 hours or so, then it started with the crash detection and after that the 9-point calibration at the start of a print would begin in the middle of the board. I had looked at belt tension, checking pulley was free, alignment of the gear on the Y-axis motor and everything seemed OK. In the end it was the Y-axis pulley gear was beginning to rub very slightly on the motor body - looking at it there was a gap, but I could feel it catch when moving with my hands. Gear is now further from the body and the belt is no longer in the center of the motor pulley. I managed to check all of these without removing the bed, so would suggest trying to remove the belt first, checking the bed moves freely, then check motor pulley on motor body before removing the bed.
Veröffentlicht : 26/04/2020 7:06 pm
OldCoder
(@oldcoder)
My newly built MK3S successfully printed a couple dozen hospital masks for our local hospital before we stopped production for mask redesign.
I printed some other parts for friends, and myself. Suddenly, it started getting crash detections, and layer shifts when it restarted printing. Even with crash detection disabled.
I did not realize that the x-axis belt had come loose from its retaining slots, and was losing tension. I tried wedging the belt into the grooves with cut off pieces of cable ties. It still would not hold tension.
I stole some timing belt off my first 3D printer. It's a little thicker than what Prusa shipped, and it is holding tension in the extruder slots perfectly! Now, the MK3S is printing nicely again
Veröffentlicht : 26/04/2020 11:03 pm
