					                		Y-Axis Crash detected - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/</link>
                <lastBuildDate>Thu, 18 Jun 2026 11:00:31 +0000</lastBuildDate>
                        <title>RE: Y-Axis Crash detected</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-406645</link>
                        <pubDate>Tue, 30 Mar 2021 08:33:00 +0000</pubDate>
                        <description><![CDATA[For me, changing Y-ball-bearings changed the situation. I replaced the originals, since then my machine runs flawlessly.]]></description>
                        <content:encoded><![CDATA[<p>For me, changing Y-ball-bearings changed the situation. I replaced the originals, since then my machine runs flawlessly.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>tox</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-406645</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-406627</link>
                        <pubDate>Tue, 30 Mar 2021 07:41:10 +0000</pubDate>
                        <description><![CDATA[I have the same issue. Did you solved yours?]]></description>
                        <content:encoded><![CDATA[<p>I have the same issue. Did you solved yours?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Hooch</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-406627</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-262168</link>
                        <pubDate>Sun, 13 Sep 2020 10:28:44 +0000</pubDate>
                        <description><![CDATA[I have gotten messages like this from an improperly seated SD (or defective SD) on occasion.  Not saying this is the cause of your warnings, but worth a check....]]></description>
                        <content:encoded><![CDATA[<p>I have gotten messages like this from an improperly seated SD (or defective SD) on occasion.  Not saying this is the cause of your warnings, but worth a check....</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JMAC</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-262168</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-262114</link>
                        <pubDate>Sun, 13 Sep 2020 07:19:22 +0000</pubDate>
                        <description><![CDATA[Hello everyone,I have the same problem too. Multiples crashes detected each time I print PETG (Prusa). Does not happen with PLA.I guess this comes from the PETG solidifying on top of top lay...]]></description>
                        <content:encoded><![CDATA[<p>Hello everyone,</p><p>I have the same problem too. Multiples crashes detected each time I print PETG (Prusa). Does not happen with PLA.</p><p>I guess this comes from the PETG solidifying on top of top layer. I significantly reduce the number of crashes by setting print speed to 50% but it is frustrating. Crashed only occur from a certain height of the head (1.5 cm approx).</p><p>I am trying longer retraction and increased fan.</p><p>Kind regards</p><p>Olivier</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>OlivierD</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-262114</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-255187</link>
                        <pubDate>Mon, 31 Aug 2020 18:57:30 +0000</pubDate>
                        <description><![CDATA[I&#039;m having the same issue. I get several y axis crashes every print. It is really frustrating..]]></description>
                        <content:encoded><![CDATA[<p>I'm having the same issue. I get several y axis crashes every print. It is really frustrating..</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Onur</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-255187</guid>
                        <title>Y-Axis Crash detected</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-253579</link>
                        <pubDate>Fri, 28 Aug 2020 19:05:29 +0000</pubDate>
                        <description><![CDATA[Hi everyone.I got the following problem:In mid-print my MK3s stops, display says &quot;Y-Axis crash detected&quot;, machine searches 0/0 on X and Y, then continues print.I have two printers, the one w...]]></description>
                        <content:encoded><![CDATA[<p>Hi everyone.</p><p>I got the following problem:</p><p>In mid-print my MK3s stops, display says "Y-Axis crash detected", machine searches 0/0 on X and Y, then continues print.</p><p>I have two printers, the one with the problem (just 2 weeks old) and an older MK3 (upgraded to MK3s).<br />Same print-code on both machines, only the new one shows errors (10 to 20 in about 6 hours printing time).</p><p>I checked the Y-carriage, it runs perfectly smooth. No obstacles, no cables in the way. Belt properly tensioned. <br />After error and zeroing the print resumes as if nothing happened just where it stopped, there are no flaws visible at the part.<br />Error occurs in various locations, not always the same spot.</p><p>I could leave it as is, the printed parts are OK. But I wonder what causes such problems and I would like to correct the issue before it gets worse.</p><p>Thanks for helping,<br />Bjoern</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-crash-detected/#post-253579</guid>
