Y-Axis Calibration Issue
Sharman
(@sharman)
Hi! I installed FullBEAR Upgrade in MK3S and I have problem with passing self-test. The fans and X axis pass correctly, but when starting the Y axis test the printer restart. Unfortunately, that's not it. I think the problem is with the stepper. But I checked it with multimeter and it showed 6.34 ohms which is normal. (I also checked it with a led and it worksXD) I swapped the motors X->Y Y->X. When I run XYZ calibration Y axis run as X axis but when X run as Y printer restart like before. What could be the problem?
Posted : 31/05/2022 4:28 pm
