XYZ axis bumpy movement - back and forth
Prodicer
(@prodicer)
https://forum.prusa3d.com/wp-content/uploads/2022/09/video_20220926_151353.mp4
Hey fellows,
my MK3S+ number 1 has an issue with the xyz movement and it's getting worse I assume.
As you can see in attached video, the movement is bumpy and it's moving back an forth instead one straight direction.
Do you know the reason and can it be fixed (by my own)?
Thx
Markus
Este debate ha sido modificado el hace 4 years por Prodicer
Respondido : 26/09/2022 1:18 pm
RE: XYZ axis bumpy movement - back and forth
Hi Markus,
I edited your post, to show the video...
never seen a response like that...  did you accidentally include Jumping Beans?
I would suggest that you have a chat session with prusa support?  BUT... I can't find it at the moment... it used to be at the bottom right hand corner of the Prusa eShop pages. and you needed to be logged in.....   I have escalated this                    issue to Prusa
maybe others can help at the moment
Respondido : 26/09/2022 3:59 pm
Prodicer
(@prodicer)
thanks Joan.
This is strange indeed. But it only affects the manual movement. The printing itself is perfect as always. Still, something has changed over time (~3000h) and I would like to know what it is.
One more thing: The black control wheel's haptic feedback has always been super soft and it's difficult to select the correct items in the control panel. I have several other and newer mk3s+ so this is why I know that the mentioned behaviour of my first printer is not common.
Thx
Markus
Respondido : 27/09/2022 8:04 am
Prodicer
(@prodicer)
Joan, I forgot. What do you mean with "did you accidentally include Jumping Beans?".
I don't know the wording.
Respondido : 27/09/2022 8:05 am
Thejiral
(@thejiral)
Could it be that this is actually an issue of the knob? When you are scrolling through the menu in one direction. Does the menu also move consistently in one direction or do you also see jumps forth and bank when scrolling down?
Respondido : 27/09/2022 8:09 am
It does look like a faulty rotary encoder.
Chat is available now - no idea why it was missing.
For support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Respondido : 27/09/2022 12:07 pm
Prodicer
(@prodicer)
ok thx, so we'll meet in the chat.
Just made another video: The first printer is the one with  the mentioned strange xyz manual movement behaviour. When turning the knob in one direction, the menu is moving down but than up again and so on. The second printer is fine as you can see. So when you turn the knob in one direction, the menu stops when reaching the end.
Respondido : 27/09/2022 12:50 pm
the Jumping beans was an attempt at a joke.
it's not important, Probably lost in translation.!
good luck
Joan
Respondido : 27/09/2022 5:33 pm
