X axis not moving, only jittering. Motor checks out on other machine. Please help!
Bryan Perry
(@bryan-perry)
Miembro
  • X axis moves freely by hand with no obstructions. Tried to reload firmware 3.14.1 with no improvement.  X axis vibrates when trying to home, but doesn't move much. I swapped X And y plugs on einsy board and X then moves appropriately using y driver slot. Is my board bad? Or is there another possible issue? Tyia!
Este debate ha sido modificado el hace 5 months por Bryan Perry
Respondido : 19/07/2025 7:03 pm
RE: X axis not moving, only jittering. Motor checks out on other machine. Please help!
Could be a dry joint or faulty connector, was it still faulty when you switched the Motor wires back?
might be worth reloading the firmware just in case...
Joan
Respondido : 19/07/2025 9:10 pm
blauzahn
(@blauzahn)
The spot where the cable goes into the stepper is prone to bending. If a cable breaks there it is not easy to repair without disassembling the stepper. When I got my MK3S years ago I immediately added this x-axis cable strain relief. You can find plenty by searching printables for MK3 strain relief.
Esta publicación ha sido modificada el hace 5 months por blauzahn
Respondido : 20/07/2025 8:12 am
