X axis belt rub against y plastic holder.
The left side of the X belt is rubbing against the front of the y-axis plastic part.
The Motor cogwheel is moved back towards the motor as much as possible.
The only way for me to move the cogwheel more to the back is if I place some wachers between the motor and the plastic part.
Is that a good idea or is there some other adjustments that I can try?
If I can move the belt back one millimeter I think it would work.
Anyone here that has had the same issue and solved it?
RE: X axis belt rub against y plastic holder.
I have found a solution:
The mounting of the cogwheel is wrong. The first picture in the manual shows the cogwheel with the grub screw down towards the bench but on the next picture it is actually turned with the grub screw at the top of the shaft. So the first picture is misleading.
