This is probably a thermistor cable, to confirm, look at:
https://help.prusa3d.com/en/guide/5-e-axis-assembly_169235 Go to step 64.
Opublikowany : 12/09/2021 5:23 pm
1 ludzie polubili
The hotend heater cables are hard to repair or replace, to determine whether you need to replace the whole lot I suggest you contact Prusa Support.
For support: Log into your Eshop account, navigate to support and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Opublikowany : 14/09/2021 5:59 pm
1 ludzie polubili
