White Sleeved Cable going to extruder head broken. What is the replacement part?
Mark Nakata
(@mark-nakata)
Hi, Looks like the white sleeve cable going to my extruder head has frayed and broke.
What is the replacement part? How would I go about fixing this?
Thanks
Respondido : 12/09/2021 3:46 pm
This is probably a thermistor cable, to confirm, look at:
https://help.prusa3d.com/en/guide/5-e-axis-assembly_169235       Go to step 64.
Respondido : 12/09/2021 5:23 pm
1 les gusta
Mark Nakata
(@mark-nakata)
Help! Ty
Thank you @Diem, the white wire is my thermistor cable. Will order a new "Hotend thermistor E3D" to fix that.
Also, I noticed this. Do you know what this wire is called? I think I need a whole new assembled hotend correct?
Respondido : 14/09/2021 4:08 pm
The hotend heater cables are hard to repair or replace, to determine whether you need to replace the whole lot I suggest you contact Prusa Support.
For support: Log into your Eshop account, navigate to support and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Respondido : 14/09/2021 5:59 pm
1 les gusta
