Which sheet is currently selected?
Mat
 Mat
(@mat-3)
Prusa i3 MK3S: In a previous firmware version, the top level menu on the printer showed the currently selected sheet.
Mine no longer shows this. It's possible to select a new sheet in the HW Setup menu under settings, however it looks like there is no way of showing which is currently selected.
Even this doc seems to show that in 3.8.0, I should be able to see the currently selected sheet in the main menu. But my printer is not showing this.
Anyone else have this problem?
Napsal : 30/11/2020 9:41 pm
RE: Which sheet is currently selected?
Hi Mat,
You need to select a build plate in HW Setup, to enable the different sheets for you to save your live Z values.
Napsal : 01/12/2020 1:10 am
