[Rozwiązany] Which firmware for MK3S+ with MMU3
Rdevine
(@rdevine)
I have an MK3S+ and a MMU3. Which firmware do I need to install?
Currently the MK3S+ is Firmware 3.14.1 and the MMU3 is Firmware 6.2.2 (3.0.3). Which one should I install?
Opublikowany : 11/03/2025 6:05 pm
3Delight
(@3delight)
Moderator Moderator
For the MK3S+ firmware 3.141 is the newest. for the MMU3 you need 896.
It can be found by going to Software -> MMU3 -> Older Versions then scroll down to: Firmware 3.14.1 (3.0.3) MK3S+, November 28, 2024 and click download.
Opublikowany : 11/03/2025 11:34 pm
