Where did the load/unload filament options go when you pause a print?
Steve Lindauer
(@steve-lindauer)
If I want to change filament midprint I used to be able to pause the print.  The unload the filament and load the new filament.  And then resume the paused print.  However, with recent firmware updates when I pause the print there are no longer options for "unload filament" and "load filament".
Napsal : 06/12/2023 9:16 pm
RE: Where did the load/unload filament options go when you pause a print?
This is not an attempt to explain where it went but you can go to Tune/Change Filament. No need for a separate Pause,
Napsal : 07/12/2023 1:42 am
2 lidem se líbí
epas
 epas
(@epas)
I'm replying quite long after your post, but many thanks : you've saved my day 👍
In addition, don't use Pause before (what I did, used to the old procedure) because once the filament swap is done, it cools down the nozzle until you resume the pause. Since the print head has been restored at the resume location just before, this can result in a small defect there.
MK3S, OpenSCAD, Blender, SolveSpace, Linux, electronics, robotics, software
Napsal : 03/04/2025 5:52 pm
