What kind of glue to use for re-attaching magnets that had fallen out of the heat bed?
Strona 2 / 3
jonnieZG
(@jonniezg)
Re: What kind of glue to use for re-attaching magnets that had fallen out of the heat bed?
I am using epoxy-glue for the job. Super-glue might be a bad idea, since most of CA glues melt above 80°C.
Opublikowany : 03/12/2018 2:09 pm
Martin_au
(@martin_au)
Loctite red. I re-did all my magnets with it. Quick, easy, and they've been holding strong for months. Just a smear on one side of the magnet. Hold it in place for 30 seconds. Done.
Opublikowany : 04/12/2018 3:39 am
Kake Prints
(@kake-prints)
Same issue here, did some long prints with ABS and 4 magnets popped out, 2 of which collided with each other mid-air and broke in 2 which changed the polarity.
Found this place which seems to be an exact replacement:
https://www.umagnets.com/p/20mmx6mmx2mm-thick-neodymium-block-magnet-n35-thin-magnets-super-strong-rectangular-rare-earth-flat-magnets-20-x-6-x-2mm/?attribute_pa_pack-of=pack-of-20
Not a bad price.
My searching for an adhesive lead me at first to tailpipe sealant as it's rated upwards to 1000c, but going to try some Sugru first as it is rated upwards to 380c which the bed would never reach in the first place. Sugru also seems much easier to remove & replace in the event the magnet weakens.
Opublikowany : 01/02/2019 6:12 am
thebbb
(@thebbb)
I had five magnets come off., none of them had glue rests on them. That indicates that the glue did not stick to the magnets. I have been working with neodymium magnets for several years now and in my experience they will only stick when you properly sand the surface of the magnet. Nothing will stick to a smooth surface, the glue requires a rough surface. I used a small screwdriver to get all of them off, sanded them and glued them back on using Gorilla Weld ($6 at Home Depot). This glue can take temperatures up to 300F (150C). I hope I will be fine now.
Opublikowany : 14/03/2019 11:05 pm
jsada.xyz
(@jsada-xyz)
RE: What kind of glue to use for re-attaching magnets that had fallen out of the heat bed?
I am having the same problem.
I glued a cople with contact glue some weeks ago and they didn't moved again.
I wrote today to support because it cotinue happening (more magnets fell down and some broke) and they suggested me to glue them with epoxy glue. They will also send me some magnets to replace the broken ones.
Probably I will unmount the bed and glue all magnets again.
Opublikowany : 15/05/2019 9:20 pm
Sembazuru
(@sembazuru)
What ever magnet you get to replace your missing and broken ones should be high temperature resistant. AFAIK, most general purpose Nb magnets will loose their magnetism when heated up. Prusa specifically says in their advertising that they use high temperature resistant magnets.
See my (limited) designs on:
Opublikowany : 15/05/2019 11:33 pm
Anyone try JB weld?  It will take 500 F or 260C sustained.
Opublikowany : 22/01/2020 6:11 pm
rmm200
(@rmm200)
Interesting thread.
All of the problem cases seem to involve bed temperatures of at least 100C. That the working limit of Prusa glue?
I hope Prusa is monitoring this. Using a higher temp glue at the factory is a really cheap solution.
Opublikowany : 22/01/2020 7:45 pm
I research this topic a lot in the past.  I clue aluminum motor retainers on rockets.  The aluminum tops out at about 240-250 C.  I can yell you I that  JB Weld easily holds for years.  I have never had it fail even with an errant ballistic recovery.
Opublikowany : 22/01/2020 8:46 pm
Gt6k
 Gt6k
(@gt6k)
Just found several of my magnets loose or having fallen off (two stuck to the rails) probably a result of 7 weeks of 24 hour PETG faceshield printing.  I'll try epoxy.
Opublikowany : 01/06/2020 3:46 pm
Alex
 Alex
(@alex-10)
Posted by: @anthony-e7
Not a bad price.
Even though this is a 2019 thread, I need to comment on this. That magnet linked is rated up to 80° Celsius and most likely will not work properly. There is high temp magnets für applications like this that will suit better.
Opublikowany : 05/08/2020 7:51 am
@alex_sc
I suggest JB weld.  You will never get your bed warm enough to weaken it.  I use it to attach aluminum rocket engine retainers on high power rocket motor blocks.  They get to 260-280C without a problem.
Opublikowany : 05/08/2020 10:49 am
Alex
 Alex
(@alex-10)
Posted by: @charles-h13
@alex_sc
You did not read my post. I did not ask for glue but gave an advice regarding the magnet suggested above.
Opublikowany : 05/08/2020 1:17 pm
@alex_sc
Yes, I can read and did read your post.  Did read the purpose of the thread?  There is no reason to be hostile or confrontational.  I am recommending this over the muffler repair product in the post you quoted.  The reason I suggest JB weld over the muffler product is it gives a stronger bond.
If magnets are what you want, I would order 2mm x 6mm x 20mm magnets from AliExpress.
Opublikowany : 05/08/2020 1:32 pm
Alex
 Alex
(@alex-10)
@charles-h13
This was not meant to be hostile, just to be clear that this was not the point of my post, since you directly adressed me. I am aware of JB Weld, you mentioned it two posts above mine, in direct reply to mine and in your last. Problem is, all my magnets are still in place and there is no JB Weld in Germany  😜
Opublikowany : 05/08/2020 2:03 pm
Posted by: @david-f42
I have two magnets that have fallen out from the bottom of the heat bed. My first thought was to superglue them back into position, but my second thought was that I'm not sure how well that would holdup to heat. So, what kind of glue should I use?
I used this one: https://www.k2-global.com/de/products/k2-black-silicone-350c-85-g
I replaced the magnets with neodymium type 45uh 20x6x2mm.
Opublikowany : 05/08/2020 2:30 pm
@alex_sc
no problem.  I did no know your location.  A couple of colleagues use JB weld in Germany.  Not sure how they get it.
Opublikowany : 05/08/2020 3:20 pm
@charles-h13
no problem: https://www.amazon.de/JB-Weld
Opublikowany : 05/08/2020 3:41 pm
Wilko
(@wilko)
Posted by: @robert-rmm200
Interesting thread.
Alas, I never heat the bed above 90 degrees (printing PET) and I had two magnets fall out of my Mk3S yesterday.
I never let the metal plate snap in place but always lowered it gradually and carefully. Just looks like the glue Prusa used to hold the magnets in place isn't up to par. I'll have to see where I can find the correct heat insensitive epoxy or glue in the Netherlands...
Prusa MK3S
Prusa SL1
Prusa CW1
Anet ET5 pro
Anycubic Mono X
Opublikowany : 15/11/2020 4:46 pm
@wilko
Maybe you try this product: https://www.amazon.de/gp/product/B00GFACVWO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I use it very often on the printer for heat resistant applications. I print PEEK at bed temperatures of 140 to 150 degrees C. and I have not lost a magnet yet.
Opublikowany : 15/11/2020 5:47 pm
Strona 2 / 3
