What happened to the textured sheet option?
aidtopia
(@aidtopia)
Today I unloaded PLA and loaded PETG and swapped out the smooth sheet for the textured one, which I've done dozens of times over the past few years.  In the main menu, there used to be a "Sheet" option.  Clicking on it would alternate through smooth, satin, and textured.  But today, there was no textured option, only smooth and satin.
So I went browsing through the Settings.  I didn't find anything obviously relevant.  When I backed out to the main menu, the "Sheet" option no longer existed in the main menu.
I think that means my first layer calibrations all got reset.  OK, so I started the First Layer Calibration process.  That requires you to select which sheet you're using, but the only choices are smooth and satin.  What happened to textured?
Printer: MK3S+
Firmware:  3.14.1-8237
Best Answer by Robin_13:
You have to setup up the sheet in the Settings > HW setup > Steel sheets.  I had to add the textured sheet yesterday.   May have changed in a firmware update.
Posted : 24/06/2025 4:29 pm
Robin_13
(@robin_13)
RE: What happened to the textured sheet option?
Posted : 24/06/2025 11:20 pm
aidtopia
(@aidtopia)
Ah, I'd forgotten about the extra level of menus there.  It's a shame the First Layer Calibration in the Calibration menu isn't the same as the one under HW Settings > Sheets.
I'm still perplexed how I lost my sheet settings to begin with.  I guess we'll never know.
Thanks
Posted : 24/06/2025 11:55 pm
Robin_13
(@robin_13)
I lost mine once and I don't know how it happened.  Forgetting things is common if you don't use them often.
Posted : 25/06/2025 12:07 am
