What exactly are those white plastic washers?
I have only a few spares, and I have a bad habit of accidentally losing them during disassembly. Are they something commonplace that I can source locally or through amazon/aliexpress?
By "white washers", I'm referring to the two translucent white plastic ones that are on the hinge of the extrusion idler.
Re: What exactly are those white plastic washers?
They are spacers for the hinge on the extruder idler gear cover
Regards Joan
McMaster-Carr is a great place to get parts like that. There is typically a wizard for selecting materials, properties, dimensions and features. I don't know exactly what those washers are because I didn't pay very close attention. They may be nothing special.
In McMaster-Carr you could look for plain washers or else "shims" and look for something around 0.115in ID (please double-check my assumption of an M3 screw). Screws often run a little small so I look for things a few thousandths under for a better fit.
perhaps this one?
https://www.mcmaster.com/#95630a234/=1d8njua oops, EDIT that one might be a lot too thick.!
here is a Mica one that might work, but be aware they are likely to be on the brittle side.
I think this is what they are Form A Washer M3 in Nylon - ISO 7089 (DIN 125A). I have brought loads of extra M3 screws and nuts from them for my various projects.
Regards,
Martin
Martin Wolfe
