What are the hotend thermistor specs for an MK3(S)?
Bas
 Bas
(@bas-2)
My hotend thermistor cable broke after a blob of death. I'm looking to replace it now, but I'm not sure what to go for, specs-wise. I'm seeing a thermistor set here that's rated up to 280 degrees Celsius, with a Semitec 104GT thermistor inside. It also mentions setting the firmware code "#TEMP_SENSOR_N 5". What setting do the stock Prusa thermistors have? I'd like to stay as close to factory specs as possible with this replacement.
Posted : 09/09/2019 8:41 am
Dave Avery
(@dave-avery)
RE: What are the hotend thermistor specs for an MK3(S)?
#define TEMP_SENSOR_0 5
Posted : 09/09/2019 8:52 am
the Prusa thermistor, IS a semitec 104 device in a protective can...
should read 100Kohms at 25Centigrade
Posted : 09/09/2019 11:26 am
It is the 104NT-4-R025H42G
Posted : 09/09/2019 2:09 pm
