RE: Weird problem
If you will post the .stl file (you will need to zip it to attach it here) I'll sure try slicing it and see if I can see any reason for it.
Posted : 21/09/2020 5:01 pm
RE: Weird problem
If I had to guess, and I do, I would say that the side that came out bad was moving as it was being printed on, and the other side remained stable. this same type of thing happens when you try to print a support for TPU to tall without somehow making the structure more ridged, and can be confused for under extrusion or some type of moisture related issue.
The Filament Whisperer
Posted : 22/09/2020 1:17 am
