Weird gaps in prints, nozzle or settings problem?
Hey all,
I recently replaced my 0.4 nozzle with a 0.6 one and started printing with the recommended settings from prusa on my MK3S+ with MMU2S. However, I noticed a very strange behavior only on a specific edge of a print, but consistently over all prints.
Any idea what might cause this issue?
Thanks in advance!
Opublikowany : 19/11/2022 12:37 pm
RE: Weird gaps in prints, nozzle or settings problem?
It's hard to judge from that picture but check your fan shroud alignment and make sure the fan blades are clean.
There are also some signs that either your smooth rods need lubrication or your belt tension is off, perhaps a bit of both.
Opublikowany : 19/11/2022 5:08 pm
