Upgraded to 3.14 and then downgraded again to 3.13
Mauro
(@mauro-3)
I have updated my trusty MK3S to the latest firmware 3.14
I'm using the printer from Octoprint and I don't know if this could have caused any of the problems.
The printer's display filament loading option has disappeared (pls see picture).
Only later did I discover that, with the same configuration, the ‘filament loading’ item now only appears if the filament is inserted in the sensor.
The biggest problem that prompted me to downgrade to 3.13 again was the management of pausing a print.
I could not find a way to restart a print that had been paused for magnet insertion. The printer display no longer shows the menu for resuming printing after pausing. I can only restart it from Octoprint, taking special care to remember to reset the temperature of the hot end, which cools down during the pause (on 3.13, resuming from LCD display caused resuming of hot end temp before resuming).
Too many things have changed for the worse, at least as far as I'm concerned; so I'm sticking with 3.13 for the time being.
Maybe we'll see what happens with 3.15.
Now that I am on 3.13 again, I am printing with absolutely no issues. Pause works again and all the LCD menus are available too.
This topic was modified 12 months temu 2 times by Mauro
Opublikowany : 21/11/2024 11:33 am
