Unload Filament problem
Alexandre Tenerife
(@alexandre-tenerife)
In the third layer suddenly no filament was loaded. I stopped printing and when I wanted to unload the filament, it doesn't happen.
Prusa tried it several times, but the filament didn't come up.
Publié : 09/04/2021 10:14 pm
RE: Unload Filament problem
Posted by: @alexandre-tenerife
We need more details:
Are you printing with the MMU or is this colour change by layer?
Does the motor turn?  Is the extruder gear clean?
Did the unload fail and prevent the load or is this a different failure?
Please tell us more.
Publié : 10/04/2021 5:46 am
Membre
Also, are you telling it to “change filament” under “Tune”?   Does it work if try to unload when the printer is not printing?
Publié : 10/04/2021 12:29 pm
kiki026
(@kiki026)
bonjour quand je lance une impression la machine chauffe fait l'etalonage de la plaque et me met un message de decharger fil elle me crache le fil et je le remet et rebolote decharge fil.
Que dois je faire ???
je sais pas si cest la les quesstions?
Publié : 16/04/2021 6:35 am
