HELP!!! Unable to pass first layer calibration
Eddiie
(@eddiie)
AAAAaaAaAaAaaAaARggg^&&$%^#$%#$#@$#
I bought my MK3s prebuilt.  It has worked great for years.   Got a new shelf, moved the printer.  Now I am unable to complete the first layer calibration..  More like I am unable to even get past the third test point on the level check.     Auto level check starts.. test point 1.. OK...  TP 2.... OK..   Test point 3.. Waaaaaaaaahhhhhhhh     Forcing Z calibration.   Great.    I see the right side lagging a bit, which is the same side the level check has started to fail on.
Everything seems level and stable.   I even put the printer back on the table it was on before and it still cant get past TP3.  Yet every time Z level calibration runs, the right side is behind a little bit..  Which should be cleared by sending Z all the way to the top.
HELP!!!!!!!!!
Best Answer by Eddiie:
One of the rubber feet on the bottom of the printer was not right. Which was not visible at the angle I was looking.
Posted : 19/10/2021 5:30 am
Dan Rogers
(@dan-rogers)
Perhaps you tweaked the frame. Time to learn to assemble the printer.
When you moved the printer, how did you support the printer so that it didn't get tweaked out of square?  From your description, sounds like you tweaked it good.  This is a job for the allen wrenches that came with your printer - start looking for what is not square.  Even if you have to go down to the frame - loosen, square, tighten.
Posted : 19/10/2021 6:23 am
Eddiie
(@eddiie)
Fixed now.
Posted : 19/10/2021 4:22 pm
