Time Remaining incorrect, Slic3r PE v1.41.0
theodore.w
(@theodore-w)
I have the latest release of Slic3rPE ( Slic3r PE v1.41.0) on my system. It seems to work well, but I printed a pair of long complex objects. Slic3r indicated that the print time would be 18 hours and 51 minutes or something like that. When I started printing, the time remaining was 6 hours and 51 minutes. It appears that the time remaining is incorrect. Perhaps it doesn't go above 12 hours? Later (over night), when I looked at the printer, the time remaining was correct at about 9 hours. This is a single data point. I haven't had a chance to do any more testing yet. I have not installed Firmware 3.4.0 yet.
Ted
Opublikowany : 20/09/2018 3:27 pm
x50arm
(@x50arm)
Re: Time Remaining incorrect, Slic3r PE v1.41.0
This was a firmware issue, update to latest firmware should fix it for you. Mine works properly after firmware update.
Opublikowany : 20/09/2018 5:26 pm
