RE: Thermal anomaly
Ik heb de thermal calibration uitgevoerd, het probleem bleift....
I have performed the thermal calibration, the problem remains....
RE: Thermal anomaly
after the latest firmware my MK3S+ with original E3D hotend setup was better than ever but my heat element in the hot end died and replaced it with a neemar(sp) V6 hotend kit with hardened .4 nozzle. great kit but the new heat element heats way too fast and trips out the thermal model and triggers Thermal Anomaly trouble code. It measures at 9.6ohms so I put a 4ohm 25 watt cemet resistor in line with one leg of it and now it heats flawlessly and at the proper temperature rise. This is getting me through until I can get a proper prusa heater element. I forgot how to do the image thing in forums so I just uploaded them in a review on amazon for the part
