					                		Temperature too high - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/</link>
                <lastBuildDate>Fri, 12 Jun 2026 23:31:41 +0000</lastBuildDate>
                        <title>RE: Temperature too high</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-622068</link>
                        <pubDate>Sat, 01 Oct 2022 12:05:14 +0000</pubDate>
                        <description><![CDATA[Ok, I found that I know someone with a thermal camera. Finally, my temps seem ok. On my TPU temp, a few off, and with the PLA temp 8 degrees. now I does not understand, why, I have print a f...]]></description>
                        <content:encoded><![CDATA[<p>Ok, I found that I know someone with a thermal camera. Finally, my temps seem ok. On my TPU temp, a few off, and with the PLA temp 8 degrees. <br />now I does not understand, why, I have print a few year with my PLA at 215/210, and now I have to reduce it to 195/190 with my last test. <br /><br />but, for my TPU, I think I have found the trouble, when I was writing this. By error, I think I have chose Generic FLEX, instead of Sainsmart TPU. Generic is at 240, and the Sainsmart is at 230, and other setting are also changed. I will redo my Gcode for my d4, and test it… </p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/10/10C4BBA4-98A2-4FE7-9672-95C74B8A395D.jpeg"><img class="alignnone size-medium wp-image-145635" src="https://forum.prusa3d.com/wp-content/uploads/2022/10/10C4BBA4-98A2-4FE7-9672-95C74B8A395D-600x480.jpeg" alt="" width="600" height="480" /></a></p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/10/D6508FAE-ED01-4262-8EEE-BCECCB8E6A86.jpeg"><img class="alignnone size-medium wp-image-145634" src="https://forum.prusa3d.com/wp-content/uploads/2022/10/D6508FAE-ED01-4262-8EEE-BCECCB8E6A86-600x480.jpeg" alt="" width="600" height="480" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Ratthy</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-622068</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621772</link>
                        <pubDate>Thu, 29 Sep 2022 00:48:37 +0000</pubDate>
                        <description><![CDATA[Do you have a known-accurate thermometer that can measure the temperature of the nozzle and headbed?Those infrared thermometers are not that expensive and can be a good sanity check on those...]]></description>
                        <content:encoded><![CDATA[<p>Do you have a known-accurate thermometer that can measure the temperature of the nozzle and headbed?</p><p>Those infrared thermometers are not that expensive and can be a good sanity check on those temperatures.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jsw</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621772</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621768</link>
                        <pubDate>Thu, 29 Sep 2022 00:40:40 +0000</pubDate>
                        <description><![CDATA[An example of what I currently have. The top picture is with my initial temperature that I alway have print with my TPU, and the second is after my first try at lower temperature. I have pri...]]></description>
                        <content:encoded><![CDATA[<p>An example of what I currently have. The top picture is with my initial temperature that I alway have print with my TPU, and the second is after my first try at lower temperature. I have print very small pin in the past, and never a blob as this. <br /><a href="https://forum.prusa3d.com/wp-content/uploads/2022/09/00207FCD-8A1F-400F-8CB5-5A0BA53EA47C.jpeg"><img class="alignnone size-medium wp-image-145569" src="https://forum.prusa3d.com/wp-content/uploads/2022/09/00207FCD-8A1F-400F-8CB5-5A0BA53EA47C-600x500.jpeg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621768</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621767</link>
                        <pubDate>Thu, 29 Sep 2022 00:38:19 +0000</pubDate>
                        <description><![CDATA[Thermisters do sometimes fail - often it&#039;s the connecting wires rather than the actual part.  It isn&#039;t anything to do with firmware.Do you have a multimeter?Measure the resistance at room te...]]></description>
                        <content:encoded><![CDATA[<p>Thermisters do sometimes fail - often it's the connecting wires rather than the actual part.  It isn't anything to do with firmware.</p><p>Do you have a multimeter?</p><p>Measure the resistance at room temperature, wiggle the cable, does the value change or go open circuit?</p><p>Then contact Prusa Support with the values you found.</p><p>For support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621767</guid>
                        <title>Temperature too high</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621766</link>
                        <pubDate>Wed, 28 Sep 2022 23:55:09 +0000</pubDate>
                        <description><![CDATA[With the latest firmware update, it’s possible that the temperature sensor give me the wrong temperature? Everything was ok before the update, after, I have to reduce the temperature of all ...]]></description>
                        <content:encoded><![CDATA[<p>With the latest firmware update, it’s possible that the temperature sensor give me the wrong temperature? <br />Everything was ok before the update, after, I have to reduce the temperature of all my print. <br />on my PLA, I have reduced the temperature by 20 degrees. <br />on my TPU, I currently making some test, and I have reduced by 50 degrees, and I will reduce the temperature again tomorrow.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/temperature-too-high/#post-621766</guid>
