Strange results after filament change
Antoine Van Vooren
(@antoine-van-vooren)
Hello,
I recently changed my white PLA filament spool. Everything was OK before... After the change I had a strange top layer. I changed fill settings (from 10 to 15%), and then had first layer adhesion issues... I always clean my bedsheet. So I tried a Z calibration to see if it was a Z or extrusion issue.
The results are a bit strange... The Z calibration seemed OK until the final square printing. Some parts of the square are correct, but there are holes in the middle... Too high Z ? Almost impossible... Inconsistent  extrusion maybe? A faulty spool?
Edit: "intermediate top layer" of the print was alright.
Can anyone help me troubleshooting this?
Thank you. 🙂
This topic was modified 2 years temu by Antoine Van Vooren
Opublikowany : 29/12/2023 11:18 am
RE: Strange results after filament change
Clogged nozze? I haven't seen it myself in years but I guess they still happen ☹️ I'd try a cold pull.
Opublikowany : 29/12/2023 12:47 pm
Antoine Van Vooren
Posted by: @fuchsr
I tried to change the filament, and it doesn't work with the other one either. So yeah, probably clogged nozzle or something similar. I tried the cold pull and inserting the acupuncture needle, neither worked... I hope it's not the extruder.
Opublikowany : 29/12/2023 8:54 pm
