Stop's at left-front corner make noise and a blob
Urs L
(@urs-l)
When i will start a First-Layer print, the printer start's normal but then he stop's in the left-front corner and creates a blop and makes a lot of noise.
large
I've done a factory reset, install again the firmware but nothing helps.
Did anybody can help me with this.
Thanks a lot
Postato : 16/10/2019 5:54 pm
RE: Stop's at left-front corner make noise and a blob
Check belts for slippage, and belt drive gears are properly attached to the motor shafts.
Also check for friction: powered off the X and Y axis should move with very little force and no sticky spots along length of travel.
It is also possible you have a corrupt profile and the startup gcode is failing.  Are you printing from the SD car or do you use the USB port?
Questo post è stato modificato 6 years fa 2 tempo da --
Postato : 16/10/2019 7:26 pm
Urs L
(@urs-l)
@tim-m30
Thanks for your ideas.
On the mechanical side, everything's fine. I use an SD card for printing.
What is the best way to reset the profile with startup code ?
Postato : 17/10/2019 10:40 am
Reload the default printer profiles in Plicer.
Beyond that, if everything is fine, you'd be printing.
Questo post è stato modificato 6 years fa da --
Postato : 17/10/2019 3:43 pm
