stopping and filament changing
diedhert
(@diedhert)
Hi all
Whenever I try to print with the filament sensor on, the printer stops every x seconds/minutes, then I need to unload filament and reload filament.
Maybe something is wrong with the filament sensor. Is there a procedure to clean (?) it or what can I do to resolve this issue.
Because I would like to print with the sensor on, so when I would run out of filament the printers pauses printing.
Regards
Diederik
Postato : 09/06/2025 11:02 am
Thomas Lynch
(@thomas-lynch)
RE: stopping and filament changing
I recently had this problem. It drove me crazy. I was trying to print some Silk Silver filament. After several tries I changed the filament to standard PLA and the problem went away. I don't know your exact situation but that fixed mine. Not what I wanted to do but it worked.
Tom
Postato : 09/06/2025 2:43 pm
diedhert
(@diedhert)
Hi Tom
Thanks for answering. In the past, I noticed it could be due to the filament, so another filament did the trick.
However, after two times pausing I changed filament, and it didn't resolved anything. I even tried a third filament, without luck.
I have been looking on the internet for any steps/protocol to follow to clean the filament sensor (if it would be possible), but I didn't find much.
Postato : 09/06/2025 5:42 pm
