					                		Sporadic ticking sound while printing - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/</link>
                <lastBuildDate>Wed, 17 Jun 2026 01:37:23 +0000</lastBuildDate>
                        <title>RE: Sporadic ticking sound while printing</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666934</link>
                        <pubDate>Tue, 01 Aug 2023 19:13:03 +0000</pubDate>
                        <description><![CDATA[Posted by: @rysten-2 I may do that. Thanks for your help. I will look at the hot end a bit further as well. If that is corrosion, would you recommend cleaning or replacement?Remplacement sin...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="527060" data-postid="666848" data-mention="rysten-2"><div class="wpforo-post-quote-author"><strong> Posted by: @rysten-2 </strong></div><p>I may do that. Thanks for your help. I will look at the hot end a bit further as well. If that is corrosion, would you recommend cleaning or replacement?</p></blockquote><p>Remplacement since your dealing with 24v</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Hello</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666934</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666848</link>
                        <pubDate>Tue, 01 Aug 2023 12:53:00 +0000</pubDate>
                        <description><![CDATA[I may do that. Thanks for your help. I will look at the hot end a bit further as well. If that is corrosion, would you recommend cleaning or replacement?]]></description>
                        <content:encoded><![CDATA[<p>I may do that. Thanks for your help. I will look at the hot end a bit further as well. If that is corrosion, would you recommend cleaning or replacement?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Rysten</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666848</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666773</link>
                        <pubDate>Tue, 01 Aug 2023 03:07:03 +0000</pubDate>
                        <description><![CDATA[That&#039;s strange contact support they will give you a new one]]></description>
                        <content:encoded><![CDATA[<p>That's strange contact support they will give you a new one</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666773</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666765</link>
                        <pubDate>Tue, 01 Aug 2023 01:03:25 +0000</pubDate>
                        <description><![CDATA[Confirmed fan, started another test print. on layers 2-4 it slowly ramps up to 100% speed (per Prusament settings in Slicer). I manually increased speed to 100 and ticking vanished. At least...]]></description>
                        <content:encoded><![CDATA[<p>Confirmed fan, started another test print. on layers 2-4 it slowly ramps up to 100% speed (per Prusament settings in Slicer). I manually increased speed to 100 and ticking vanished. At least I ordered 2... I doubt replugging would help try and fix this one?</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666765</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666763</link>
                        <pubDate>Tue, 01 Aug 2023 00:45:15 +0000</pubDate>
                        <description><![CDATA[See album for photos of board connections and hotend during ticking. I unplugged/replugged the connection and ran thermal again. Ticking happened at the end of R section after fan speed ...]]></description>
                        <content:encoded><![CDATA[<p>https://imgur.com/a/KGjMvCO See album for photos of board connections and hotend during ticking. I unplugged/replugged the connection and ran thermal again. Ticking happened at the end of R section after fan speed spun down a little through rest of the test. That gave me a thought, could it be the fan motor at certain speeds? This would suck as it is a brand new fan, I also had a little trouble getting it installed into the right position, the exhaust port didn't want to fit in to allow screw holes to align.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666763</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666684</link>
                        <pubDate>Mon, 31 Jul 2023 14:32:04 +0000</pubDate>
                        <description><![CDATA[I can get a photo of that this afternoon. And I am not sure if that is corrosion or filament. The blob I has was a dark grey filament (Prusament Gentleman&#039;s Grey IIRC).]]></description>
                        <content:encoded><![CDATA[<p>I can get a photo of that this afternoon. And I am not sure if that is corrosion or filament. The blob I has was a dark grey filament (Prusament Gentleman's Grey IIRC).</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666684</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666599</link>
                        <pubDate>Mon, 31 Jul 2023 02:31:19 +0000</pubDate>
                        <description><![CDATA[first off sorry for late reply um is that corrosin or fillament and could you take a photo of the einsy end conection and undo the connection and then re insert it]]></description>
                        <content:encoded><![CDATA[<p>first off sorry for late reply um is that corrosin or fillament and could you take a photo of the einsy end conection and undo the connection and then re insert it</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666599</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666596</link>
                        <pubDate>Mon, 31 Jul 2023 01:22:20 +0000</pubDate>
                        <description><![CDATA[See link for two photos of wiring into hotend.Print had zero issues that I can see.]]></description>
                        <content:encoded><![CDATA[<p>See link for two photos of wiring into hotend. https://imgur.com/a/OEdvKZy Print had zero issues that I can see.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666596</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666581</link>
                        <pubDate>Sun, 30 Jul 2023 23:27:14 +0000</pubDate>
                        <description><![CDATA[OK make sure to keep an eye on it and let me know when done]]></description>
                        <content:encoded><![CDATA[<p>OK make sure to keep an eye on it and let me know when done</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666581</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666579</link>
                        <pubDate>Sun, 30 Jul 2023 23:20:48 +0000</pubDate>
                        <description><![CDATA[No issues with the print so far. Doing two of the sample object galaxy wheels as the other spool of this filament would cause failures between sometime during the 3-4 hour mark regularly. Pr...]]></description>
                        <content:encoded><![CDATA[<p>No issues with the print so far. Doing two of the sample object galaxy wheels as the other spool of this filament would cause failures between sometime during the 3-4 hour mark regularly. Pre fan swap I did a 14 hour print with a glow-in-the-dark PLA that had no issues.</p><p>That is one of the reasons I have been at loss to the cause of the ticking. I would have assumed it would be more consistent and occur during heatup phase (preheat or otherwise) or happen on all layers, not just 2-4.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/sporadic-ticking-sound-while-printing/paged/2/#post-666579</guid>
