slic3r pe functionality question - "Remove all holes"
magiclantern
(@magiclantern)
I have some models that have interior cavities that I want to fill in. One example is this model https://www.thingiverse.com/thing:32016
In Cura, it has a feature called "Remove all holes" - see details at https://ultimaker.com/en/resources/20424-mesh-fixes - that removes interior cavities and allows the printer to fill the interior at the selected fill rate.
Does slic3r have a similar feature? I really like all the settings on slic3r and how it is tuned to work with the MK3, so I'm worried about using Cura to print on my MK3.
Napsal : 08/02/2019 6:18 am
toaf
 toaf
(@toaf)
Re: slic3r pe functionality question - "Remove all holes"
you should be able to make a modifier to fill everything.
Napsal : 08/02/2019 6:54 am
magiclantern
(@magiclantern)
toaf - thanks for the recommendation. I've never heard of that feature of slic3r before. Do you have any recommendations on how to learn how to use modifieres?
Napsal : 08/02/2019 4:53 pm
toaf
 toaf
(@toaf)
the modifiers are neat, they act almost just like support modifiers
Napsal : 08/02/2019 8:28 pm
