Sheet Profiles and Keeping Track
JerryM
(@jerrym)
For those of you with the new firmware, configured for sheet profiles, and have three or more sheets... How do you keep track of which is which? I initially thought about using a white permanent marker to put a number in a corner outside of the print area. However, I'm concerned about heat bed temperatures causing issues. A Dymo-type label will probably also have adhesion issues when heated. Any other ideas?
Posted : 04/10/2019 8:27 pm
RE: Sheet Profiles and Keeping Track
I have embraced using @jbinfl's trick of placing a strip of blue painter's tape in one corner and marking it with the Live-Z used. Plenty of of room to add a name. A squirt of isopropyl alcohol and the markings wipe away (just not towards the print area) for quick updates.
Posted : 05/10/2019 3:13 am
@bobstro
This is what I do too.  I now have multiple printers so I added: "A -0.599" , "B -1.211".  The letter is the printer.
I have just begun to use the printer software to add them but it is a little cumbersome.
Posted : 05/10/2019 11:38 am
