[Rozwiązany] Self Test Error - Please check axis length Y
Strona 1 / 2
emotionalvampire
(@emotionalvampire)
So yesterday, I tried printing something in PLA which obviously was too thin and detatched from the bed leaving behind loads of plastic to clear up. After clean up I adjusted the print and tried again.  During the leveling test, the bed banged at the the back of the printer, then came forward and banged around.  I stopped the print and ran the self test and then got the 'Please check axis length' on Y error.
I took the hot bed off to check for anything I missed and could see nothing. No wire or bits of left over plastic blocking anything.  I can go into Settings and manually play with the Y axis and make it smoothly go from front to back to front again.
The only things I have found were the rear bearing was loose and a bolt on the pully that connects to the motor was also loose.  Everything seems fine, just will not complete the test.
PLEASE HELP!!!
Opublikowany : 29/09/2019 11:17 am
RE: Self Test Error - Please check axis length Y
Try doing an AutoHome then try the test again.
The Y bearings need to be held snug with the U-bolts, but not tight.  If too tight the bearing drag can cause Y crashes (motor stalls); and these will cause a fail.
And the Y belt drive gear should be attached using the flat first method: fully loosen both set screws, carefully align then tighten the set screw on the flat of the motor shaft; and then tighten the jam set screw.  To adjust the gear, first loosen the jam screw, then the flat set screw or you risk stripping out the hex.
Opublikowany : 29/09/2019 7:51 pm
emotionalvampire
(@emotionalvampire)
Well good news!  Im fixed
I checked the auto home and still same problem. Checked the 3 bearing and tightened just enough so I could no longer move with my finger.
I took the Y belt gear off and thats when I found my problem.  Some of the plastic had wrapped itself around the gear making the belt slip ( i guess).  Once everything was put back together, Y axis configured fine.
Thanks for your advice
Opublikowany : 30/09/2019 3:11 pm
takanotume24
(@takanotume24)
Hi, I was having the same problem with the same error, but I solved it by checking the hardware.
In my case, the screw that connects the motor and the gear of Y-axis was loose, so I tightened it with a hexagonal screwdriver. Then the self test can be passed.
Thank you!
Opublikowany : 21/09/2020 3:51 pm
michael-5
(@michael-5)
I started experiencing the self test error yesterday.  The belt test passed the x axis test but as soon as it tried to move along the y axis it failed.
I tried moving the platform manually and found that it would move then stick. If I pushed through the sticking, it would move again for a bit and stick again.  I then loosened the pulley set screws so the motor wasn't involved and the platform rolled smoothly.
Not sure what to do at this point.  I tried contacting tech support but Chrome wouldn't do anything when I clicked on the tech support button.
Opublikowany : 23/09/2020 5:05 pm
osmosis
(@osmosis)
@michael-5
I am having this exact same problem.  Have you found a resolution?
Opublikowany : 31/10/2020 1:09 am
@kevin-b60
There are a few problems listed above. Which one are you having?
Opublikowany : 31/10/2020 3:59 am
osmosis
(@osmosis)
I had the y-axes problem.  I found my solution.  I had a y-belt of 237, so I had the bearing too tight.  I loosened them up and realigned the pully.  That fixed my problem.
Opublikowany : 01/11/2020 12:45 am
JuustoMestari
(@juustomestari)
I had the same issue today. It turns out I just had to grease the y axis rods.
Opublikowany : 09/01/2021 11:15 am
2 ludzie polubili
PauloSouza
(@paulosouza)
@osmosis
I do the same, and it worked!
Opublikowany : 28/01/2021 12:51 pm
Brian
(@brian)
I have just finished assembly.  First 3D printer, and nothing to compare to.  Got through all the self checks first time through.  I was doing the "Z" adjustment, and now I continually get Y axis failures.  Also seems to have lost "home".   Checked belt, zip ties... no mechanical issues I can tell.  One thing since the beginning, is that the Y axis moves in "spurts" when moved by hand - seems like magnetic resistance at points.  Moving it with the control panel and during the initial testing, it ran fine.
When running the belt test, the bed moves about 2" both ways, then stops and throws a fail - Axis Y error.
Any help is appreciated.
Opublikowany : 25/06/2021 2:32 am
hspter
(@hspter)
I ran into this, and it ended up being because I hadn't tightened the screws that housed the rods. So the M3 screw head was sticking out, and the ybed frame was hitting it when moving back and forth.
Opublikowany : 26/08/2021 10:17 pm
1 ludzie polubili
RobertI
(@roberti)
Y axis
Thank you, this tip worked for me, grabbed some spray oil that we use for cooking and I’m back in business 😉
Opublikowany : 10/09/2021 9:33 am
Oops!  Cooking oil will oxidise and turn to sticky gunk in a little while... Better to clean it off and replace with mineral oil.
Opublikowany : 10/09/2021 3:39 pm
OeschMe
(@oeschme)
I had same issue, turned out I had places bearings (on the side where there's two) slightly wrong. Front bearing was too far front and rear bearing too far back. That caused Y to "crash" like under 1mm from target length.
Hobbyist (enthusiast) from Finland
Prusa Mini+
MK3S+ w/ MMU2S
Fusion 360
Opublikowany : 22/08/2022 1:07 pm
Michael Lamoureux
(@michael-lamoureux)
RE: Four screws
Thanks @hspter! This was exactly my problem too. The four M3 screws were not screwed in, for the two Y-rods. I don't know how I missed that step in the assembly instructions!
This post was modified 3 years temu 2 times by Michael Lamoureux
Opublikowany : 02/04/2023 4:32 am
Jared G
(@jared-g)
To second another earlier post here from JuustoMestari, I ran into this issue and after reading some other threads on this forum I started the maintenance process. Right after cleaning and lubricating the rods under the bed (along the y axis), literally the first step of the maintenance process, this issue went away as well as my 'crash detected' issues and my low belt tension values. It was just hanging up as it slid along, causing the error. Definitely the first stop for readers coming to this thread for solutions.
This post was modified 3 years temu 2 times by Jared G
Opublikowany : 17/06/2023 3:43 am
MG
 MG
(@mg-5)
After a year of perfect prints, I developed the same problem.  Y axis would move manually but seemed really stiff.  I lubed the y axis guide rods and, voila, it’s working perfectly. Unfortunately, I first did a factory reset and had to re-do my calibration.
Opublikowany : 23/06/2023 10:52 pm
jwvanderbeck
(@jwvanderbeck)
What do you use to lube them and is there a procedure somewhere?  I am having this problem as well after about a year and a half.  Mine was a pre-assembled kit, so I don't really know the nuts and bolts on how it goes together, but the Y axis is failing test and if I try to move it by hand it is VERY hard to move.  I can't visually see any obstructions, though I didn't disassemble anything.
Opublikowany : 09/07/2023 2:34 pm
Vašek M.
(@vasek-m)
Hi!
I had the same issue. Cleaning and greasing of all rods helped me 🙂
Opublikowany : 02/08/2023 10:03 pm
Strona 1 / 2
