Self Calibration Test X Axis failing kind of.
Mullcom
(@mullcom)
Hi...
I found something today that's was a bit strange.
When i do a self Test in calibration menu i get Pass on X Axis when i have extruder at bottom. But when i have extruder at top it failing.
https://photos.app.goo.gl/LSyDbJzq5ufB9habA
Napsal : 04/01/2021 5:03 pm
RE: Self Calibration Test X Axis failing kind of.
Might be worth contacting support via chat. It's possible something is out of alignment higher up. If nothing else, the self-check should test extremes.
Napsal : 04/01/2021 5:17 pm
1 lidem se líbí
McNezmo
(@mcnezmo)
Exactly the same problem. After recalibration when extruder was on top, then error occur. When I moved extruder down, then selftest passed OK.
Napsal : 22/01/2021 12:32 pm
