Request for Configuration.h File for Prusa MK3S
Bywhitex
(@bywhitex)
Prusa MK3S tasarımına dayalı özel yapım bir 3D yazıcım var. Yazıcımı düzgün bir şekilde kurabilmek ve kalibre edebilmek için Configuration.h dosyasını veya MK3S modeline özgü herhangi bir üretici yazılımı yapılandırma dosyasını talep etmek istiyorum.
Ürün yazılımı dosyalarının açık kaynaklı olduğunu anlıyorum ve rehberliğiniz veya doğru dosyalara doğrudan bir bağlantı için minnettar olurum.
Desteğiniz için çok teşekkür ederiz!
system info serial2Saygılarımızla,
Posted : 26/04/2025 1:13 pm
RE: Request for Configuration.h File for Prusa MK3S
Look in the Prusa GIT HUB, that referres to the printer that your model is based upon. !regards Joan
Prusa GITHUB'a bakın, modelinizin dayandığı yazıcıya atıfta bulunuyor. !saygılar Joan
Posted : 26/04/2025 3:31 pm
Bywhitex
(@bywhitex)
Title: MK3S Stops Mid-Print – Need Help with Configuration File and Firmware Compatibility
Hi everyone,
I recently bought a second-hand Prusa MK3S. Unfortunately, the previous owner didn’t provide a backup of the original configuration file, and at the time, I didn’t know it was something important to keep.
I’m having trouble understanding which firmware version is compatible with which hardware. GitHub feels overwhelming to me, and I’m not confident about what works with what.
The printer has a filament sensor installed, so it automatically identifies as an MK3S. However, during prints, it often stops around 33% progress. It doesn’t give any error message — sometimes it just moves the print head to the front and goes into a kind of pause or wait mode. I’ve watched many videos and tried different things, but I still haven’t found a solution.
I suspect that the issue might be related to the configuration file, or possibly a mismatch in firmware settings. I would really appreciate it if someone could guide me step by step to make sure my setup is correct.
One of the reasons I chose Prusa was because of the strong community and support — so I’m hopeful I can get this resolved with your help.
Thanks in advance, and best regards!
Posted : 26/04/2025 6:32 pm
