Replacement Einsy RAMBo Power Connectors
PotatoFi
(@potatofi)
I need to replace the screw-down power connectors on the bottom of my Einsy RAMBo. The bed ground connector was loose (someone else assembled this printer), which caused arcing and ended up melting the connector.
They look like a pretty straightforward desolder and resolder. I just need to find out what part to purchase. Anyone happen to know what it is? I would like to get an exact replacement if possible.
Thanks!
Posted : 13/03/2020 4:14 am
K7ZPJ
(@k7zpj)
RE: Replacement Einsy RAMBo Power Connectors
You can get the connector information from the board schematic: https://github.com/ultimachine/Einsy-Rambo/blob/1.1a/board/Project%20Outputs/Schematic%20Prints_Einsy%20Rambo_1.1a.PDF
Here is the link to the connector:
TE Connectivity 2-1437667-9
Posted : 13/03/2020 5:37 am
PotatoFi
(@potatofi)
This is exactly what I needed, thank you very much! I have one ordered. I did poke around on GitHub but didn't land on that specific PDF for some reason, thank you very much for the help.
Posted : 15/03/2020 6:26 pm
