Reclaiming a tungsten nozzle?
I'm wondering if anyone else has had this issue.
About a year and a half ago I switched to a tungsten nozzle on the MK3s (ca. US $50). It's been performing fine until very recently.
A model I was printing had a vertical shaft with lots of artifact, so I did an inspection of the works and found the filament to be coming out at an angle when manually advanced. This has happened before a couple of times, but it was always easy to fix.
I did a 'cold pull' with cleaning filament and probed the hot nozzle with an acupuncture needle with no effect.
I then got out one of the .4mm cleaning bits and mounted it in a pin vise, got the nozzle good and hot, and attempted to clean out any obstruction that way, something that I have done a few times over the years.
Unfortunately, the cleaning bit broke right at the nozzle opening as I was twisting.
There is not nearly enough of the bit sticking out to grab and pull. I heated it to 280C or so and tried to push the remains of the bit upward with both the broken stub of the bit and a needle. It will not budge.
I then pulled the nozzle out, put it on the bench, clamped it to the tip of a soldering iron, got it very hot and again tried to force it one way or the other, no go.
I installed a regular brass nozzle to get the machine back up again (works fine) but I would sure like to get the tungsten one working again.
Has anyone had a similar situation? If so, how did you clear it.
Thanks.
RE: Reclaiming a tungsten nozzle?
Instead of heating it, you could try freezing it and then trying to tap it out. If your 'cleaning bit' has a higher expansion coefficient than tungsten then heating it will actually make it tighter.
Let me try that, and that might explain why the bit bound and snapped, as the nozzle was hot when I did it. Thanks.
I'm going to second what @neophyl said and add that once you get the whole thing cold you could try heating the nozzle with a soldering iron, if the bit says cold and the nozzle warms that could open more space to get the bit out.
Cheers
-Bob
