Purchasing parts
How do I go about purchasing parts. The wires on the hot end heater in my MK3S broke off and I need to replace the heater.
Posted : 13/03/2020 7:55 pm
RE: Purchasing parts
Click the EShop button above and register / log in.
Then click Spare Parts.
Prusa compatible heaters are available pretty much anywhere. If you choke on shipping costs - you might see what is available locally.
That being said - I do like to support Prusa when I can. I consider the man a force for good.
All of his designs are public domain - and his vision shaped an industry.
Posted : 13/03/2020 10:45 pm
@leroy-12 , If you do not buy Prusa original parts, make sure you order the right voltage. It should be 24 volts, not 12 volt.
Posted : 14/03/2020 3:53 pm
