					                		Pulley screws too tight prevents proper operation - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/</link>
                <lastBuildDate>Mon, 08 Jun 2026 08:09:19 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-520009</link>
                        <pubDate>Thu, 28 Oct 2021 18:23:47 +0000</pubDate>
                        <description><![CDATA[Thank you for clarifiying]]></description>
                        <content:encoded><![CDATA[<p>Thank you for clarifiying</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>BogdanH</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-520009</guid>
                        <title>UPDATE</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519916</link>
                        <pubDate>Thu, 28 Oct 2021 15:35:08 +0000</pubDate>
                        <description><![CDATA[Belt on.My theory is that when I tightened the set screws, I moved the pulley up against the motor, thereby interfering with free turning of the shaft. I loosened the screws, moved the pulle...]]></description>
                        <content:encoded><![CDATA[<p>Belt on.</p><p>My theory is that when I tightened the set screws, I moved the pulley up against the motor, thereby interfering with free turning of the shaft. I loosened the screws, moved the pulley a bit away from the motor, and re-tightened. I think it's OK now.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>roc856</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519916</guid>
                        <title>Yeah, that&#039;s not it</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519628</link>
                        <pubDate>Thu, 28 Oct 2021 05:44:40 +0000</pubDate>
                        <description><![CDATA[Print yourself a belt tension gauge.  You got something much bigger going on.  Unless you got the wrong pulley/shaft diameter a semi tight and very tight pulley are indistinguishable to the ...]]></description>
                        <content:encoded><![CDATA[<p>Print yourself a belt tension gauge.  You got something much bigger going on.  Unless you got the wrong pulley/shaft diameter a semi tight and very tight pulley are indistinguishable to the printer.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Dan Rogers</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519628</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519601</link>
                        <pubDate>Thu, 28 Oct 2021 05:06:39 +0000</pubDate>
                        <description><![CDATA[That&#039;s the first time I hear that to be the case. Did you re-tighten screws with belt on, or did you readjust belt tension too?]]></description>
                        <content:encoded><![CDATA[<p>That's the first time I hear that to be the case. Did you re-tighten screws with belt on, or did you readjust belt tension too?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519601</guid>
                        <title>Pulley screws too tight prevents proper operation</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519496</link>
                        <pubDate>Wed, 27 Oct 2021 19:57:10 +0000</pubDate>
                        <description><![CDATA[I tightened the Y-axis pulley screws, and my printer then failed to operate. For example, the belt test resulted in Y-axis failure. (Not an out-of-range number, but flat out failure.)(Note t...]]></description>
                        <content:encoded><![CDATA[<p><img src="https://basepath.com/public/Screenshot pulley.png" alt="pulley" width="300" height="300" /></p><p>I tightened the Y-axis pulley screws, and my printer then failed to operate. For example, the belt test resulted in Y-axis failure. (Not an out-of-range number, but flat out failure.)</p><p>(Note that the picture isn't the Y-axis motor -- I just wanted to show what I meant by pulley screws.)</p><p>Then I loosened the screws a little, leaving them snug but not apparently too tight, and the printer started to work again.</p><p>Why are too-tight screws a problem?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pulley-screws-too-tight-prevents-proper-operation/#post-519496</guid>
