[Solved] PrusaSlicer Import STL problem
Pedroid
(@pedroid)
attached is a simple STL containing 2 orthogonal planes with thickness of 2 mm. One of the plane is rectangular, the other has a 45° angle.
When importing the file into PrusaSlicer the thickness of the plane with the angle decreases from the left button side to the right upper side from 2 mm to 0. I can find the same behavior in Slic3r purse edition but not in Cura. The STL file has been created by the STL Import & Export Add-on in Sketchup.
Eckanrisshilfe.stl
Best regards
Olaf
Best Answer by --:
Even Netfabb is not liking it; declares it non-manifold. Rectangles are all triangles, and have cross connected corners. Escher-like.
Repaired
Posted : 23/06/2019 10:15 am
RE: PrusaSlicer Import STL problem
Slicer is reporting 6 errors ... Meshmixer found the weld isn't a weld.
This post was modified 7 years ago by --
Posted : 23/06/2019 3:35 pm
Repaired
Posted : 23/06/2019 3:43 pm
Pedroid
(@pedroid)
Thank you very much.
Posted : 23/06/2019 5:41 pm
Pedroid
(@pedroid)
Supplement for Sketchup users: The extension Solid Inspector2 in the extension warehouse seems to be promising. It can detect and fix various problems in solids before exporting the STL.
Posted : 24/06/2019 6:01 pm
