Prusa Slicer Introduces Unwanted Infill & Bridge Supports
RE: Prusa Slicer Introduces Unwanted Infill & Bridge Supports
Here are screenshots from PrusaSlicer
If this is a request for help, great; but if this is an attempt to add to a bug report, the peer to peer forum is not the right place to post it up. Github is where bug reports belong and the only place they are responded to. Though once in a while a dev will respond here, it isn't expected.
Try this part: see if it works any better.
@tim-m30
Thanks. Looking for help.
I found the "fix with netfabb" command in the context-sensitive menu by left clicking on the object in the left hand panel. That fixed it once, and nicely. But now I'm trying to print a pyramid shaped shell and I get the unwanted infill even when I set infill to 0 and then fix with Netfabb.
Any insights are welcome.
Update: It seems that when exporting STLs out of Blender, it is necessary find the "Export STL" panel in the lower left hand corner of the File/Export window and check the "Selection Only" box. This seems to stop the problem of unwanted geometry appearing in PrusaSlicer.
