prusa mk3s not extruding during printing but extruder working
[Rozwiązany] prusa mk3s not extruding during printing but extruder working
francois
(@francois)
Hello,
I am facing exactly the same problem as described in the following post :
      https://3dprinting.stackexchange.com/questions/16586/prusa-mk3s-not-extruding-during-printing-but-extruder-working
I was not able to find any question related to such a problem on this forum, hence I opened this topic.
I will add that, when I start a print:
  • the printer is able to extrude the first line after bed level verification,
  • but, when it start to print the outline of the printing, nothing is extruded anymore,
  • the extruder gears are rotating ,
  • same problem with different filaments,
  • same problem with different filament materials,
  • modifying the tension on the Extruder-idler changes nothing.
Before disassembling and reassembling the printing head, does somebody here got an idea ?
Thanks.
Best Answer by JoanTabb:
set live Z to 0.00 and see if the extruder dribbles filament strands at all.
if live Z is too low, the build plate effectively blocks the nozzle and often causes the bondtech feed wheels to click
if the printer now extrudes filament, re do your live Z.
Opublikowany : 09/12/2022 10:10 am
RE: prusa mk3s not extruding during printing but extruder working
Opublikowany : 09/12/2022 5:02 pm
My list of suspects:
The idler screw too tight or too loose (okay, you checked that )
Partial blockage of the nozzle.
Live Z too low ( as Joan suggested)
Trying to print PETg at PLA temperature.
And in the category of wild ideas:
Something like a piece of filament stuck under the steel sheet
Opublikowany : 09/12/2022 5:27 pm
alex
 alex
(@alex-28)
Have you checked the ptfe tube.
Opublikowany : 10/12/2022 1:33 am
francois
(@francois)
thanks much Joan for the head up !
I re calibrated the Z axis and then re adjusted the first layer and ... tada ... it worked again !
I still wonder what occurred here after 5kms of filament printing without having to re calibrate the machine, except when I was changing the kind of steel sheet.
cheers,
François.
Opublikowany : 10/12/2022 8:36 am
francois
(@francois)
little picture of my baby back to life ...
Opublikowany : 10/12/2022 8:45 am
francois
(@francois)
Thanks Fushsr for your advised suggestions .
Opublikowany : 10/12/2022 8:58 am
You know, it just happens. Maybe the part keeping the PINDA in place is a bit sagging. I've seen this happen (and not just "a bit") on 2 machines after printing stretches of ASA. Or more likely if all you print is PLA, the screw holding that part right worked itself a bit loose. You may want to give it a turn with the Allen wrench.
Opublikowany : 10/12/2022 10:54 am
francois
(@francois)
ok, thanks, will do !
I print mostly PETG / ABS / ASA / PC not too much PLA
Opublikowany : 10/12/2022 10:58 am
