Prusa i3 mk3s print recovery after long period of time.
Is there a way that I can use the power panic feature to pause a print and save it for the next day. I had a creality machine in which I could pause, shut off and return the next day to continue the print. I understand that the print could warp but I am just wondering if this is possible to do and how I could do it. Thanks!
Opublikowany : 12/03/2020 3:51 am
RE: Prusa i3 mk3s print recovery after long period of time.
You technically can, but if the PEI sheet cools off, there's a very good chance the part will pop off. With a surface like BuildTak, it might be more reliable.
Opublikowany : 12/03/2020 3:56 am
