Prusa Control Freezing on loading
michael.m61
(@michael-m61)
I'm having a failure to load script error on launch of Prusa Control. This just started.
Here are the logs.
[ERROR][main.py:95:log_exception()]-Logging an uncaught exception
Traceback (most recent call last):
File "main.py", line 193, in <module>
File "main.py", line 159, in main
File "controller.py", line 65, in __init__
File "parameters.py", line 357, in __init__
File "parameters.py", line 497, in check_versions
File "parameters.py", line 576, in get_materials_info
File "json\__init__.py", line 265, in load
File "c:\python35\lib\encodings\cp1252.py", line 23, in decode
UnicodeDecodeError: 'charmap' codec can't decode byte 0x8d in position 54870: character maps to <undefined>
Any help will be appreciated
Posted : 24/09/2018 6:27 pm
Dave Butler
(@dave-butler)
Re: Prusa Control Freezing on loading
I am having the same problem today. Never happened before. I have updated the software to the latest edition, but still get the fatal error message.
Posted : 24/09/2018 6:40 pm
Nebulus
(@nebulus)
Same Here, a Hidden windows says : Fatal Error ! Failed to Execute script main
Never had this before 😮
Posted : 24/09/2018 6:55 pm
Nebulus
(@nebulus)
and... same on a second computer, just installed it, probably an issue with some W10 Update... ?
Posted : 24/09/2018 7:07 pm
Jack
 Jack
(@jack-7)
Same problem with Prusa Control script load failure
Posted : 24/09/2018 7:31 pm
hot_poker
(@hot_poker)
Any progress on this issue. I have the same error with the same prusacontrol.log file
Posted : 24/09/2018 7:47 pm
JLB
 JLB
(@jlb-2)
Same behavior.
On 3 different Win10 machines, 32 & 64 bits.
Posted : 25/09/2018 2:33 pm
oa
 oa
(@oa)
Here is how I fixed this issue (was trying to find the link to the site I found this solution but could not locate it now):
1) Reinstalled Prusa Control
2) Deleted all contents on my computer, under the following folder:
C:\Users\<your windows username here>\.prusacontrol
3) Downloaded all the contents from the following prusa control repository:
https://github.com/prusa3d/PrusaControl-settings
4) Pasted in the directory noted on step #2 above
It just worked 🙂
Edit: I am running Windows 10
Posted : 26/09/2018 4:55 am
