Pronterface not connecting
Mustrum Ridcully
(@mustrum-ridcully-2)
I am trying to use MACPronterface but it is not connecting the ensi is plugged in to the USB on the Mac.
what I see trying the buttons on the interface page is this: I expect it is something simple but I dont see it the port box has 2 instances of
/dev/tty.Bluetooth-Incoming-Port and /dev/cu.Bluetooth-Incoming-Port no sign of USB and selecting either of them makes no change.
Connecting...
Reset.
plate function activated
Connecting...
Can't read from printer (disconnected?).
Connecting...
Connecting...
Connecting...
Reset.
Connecting...
Connecting...
Connecting...
Napsal : 19/11/2018 5:32 pm
Re: Pronterface not connecting
Hi Randolph,
Have you checked the the internal Raspberry Pi port is disables on the LCD Menu?
Napsal : 19/11/2018 5:35 pm
Mustrum Ridcully
Hi Joan,
yes RPi is off and I dont have a Zero I bought a 3W but I have not got it working yet or installed it.
Napsal : 19/11/2018 5:44 pm
Mustrum Ridcully
turned out to be a bad USB cable... but I got it working with one from my "closet of computer history' from the "bag of holding"(cables) right next to the SCSII cables from 1984 😀
every time I run the mesh leveling it comes out differently here is the last one ... they were getting a tiny bit worse every time
0.33833 0.45981 0.55370 0.62000 0.65870 0.66981 0.65333
0.31769 0.43344 0.52162 0.58222 0.61526 0.62072 0.59861
0.29185 0.40331 0.48695 0.54278 0.57078 0.57097 0.54333
0.26083 0.36944 0.44972 0.50167 0.52528 0.52056 0.48750
0.22463 0.33183 0.40992 0.45889 0.47874 0.46949 0.43111
0.18324 0.29047 0.36754 0.41444 0.43118 0.41776 0.37417
0.13667 0.24537 0.32259 0.36833 0.38259 0.36537 0.31667
Napsal : 20/11/2018 12:26 am
