Problems with filament change resume?
I've had a couple of situations where I've run out of a filament during a print. The extruder moves to the corner and prompts me to unload the old filament and insert the new one. All works fine. The extruder then moves to where it left off.................and sits. And sits.
The software doesn't continue the print. It just sits for some reason. I meant to catch the log entry for it, but disconnected the printer before documenting (doh!). I'll force a filament change after this print finishes and see if I can get the log entries for it.
Has anyone else had trouble with this feature not working? I wanted to try printing multi-color using filament changes, but not if it keeps failing on mono-color stuff.
Publié : 18/03/2019 2:37 pm
