					                		Problem with heated bed - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/</link>
                <lastBuildDate>Tue, 16 Jun 2026 06:42:58 +0000</lastBuildDate>
                        <title>RE: Problem with heated bed</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-741714</link>
                        <pubDate>Sat, 22 Mar 2025 10:01:09 +0000</pubDate>
                        <description><![CDATA[ExcellentRegards Joan]]></description>
                        <content:encoded><![CDATA[<p>Excellent<br />Regards Joan</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-741714</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-741702</link>
                        <pubDate>Sat, 22 Mar 2025 07:03:31 +0000</pubDate>
                        <description><![CDATA[Hi JoanTabb, thanks for your reply.Indeed, it was a first-layer issue, and changing the bed leveling to 7x7 mesh solved the problem.Best regards!]]></description>
                        <content:encoded><![CDATA[<p class="p1">Hi JoanTabb, thanks for your reply.</p><p class="p1">Indeed, it was a first-layer issue, and changing the bed leveling to 7x7 mesh solved the problem.</p><p class="p1">Best regards!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Jaume</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-741702</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-739359</link>
                        <pubDate>Fri, 07 Mar 2025 10:16:19 +0000</pubDate>
                        <description><![CDATA[it is unusual for  a section of the bed to be  hotter than the restlooking at your first layer image, I think I can see a little waviness in the surface to the lower left area and a blob on ...]]></description>
                        <content:encoded><![CDATA[<p>it is unusual for  a section of the bed to be  hotter than the rest<br />looking at your first layer image, I think I can see a little waviness in the surface to the lower left area and a blob on waviness to the  upper right area. this suggests that the nozzle is too close to the build plate in these areas<br />Could you please remove the build plate and ensure that there is nothing trapped between the heat bed and the build plate, especially in the top right corner! <br /><br />is your printer  doing 9 point mesh bed levelling? (3X3 mesh)<br />If so, could you please set it to do 7x7 mesh bed levelling<br />https://help.prusa3d.com/article/mesh-bed-leveling_112163<br />then please re do the live Z adjustment, I expect the ideal live z value should be a little smaller negative number than you are currently using. <br /><br />then when all is well, <br />try the large surface print again. <br /><br />regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-739359</guid>
                        <title>Problem with heated bed</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-739346</link>
                        <pubDate>Fri, 07 Mar 2025 09:26:26 +0000</pubDate>
                        <description><![CDATA[Hello, after a long time without using it, I&#039;ve started up my MK3S printer again. The issue is that I noticed some areas of the first layer of the printed part appeared slightly burnt. So, I...]]></description>
                        <content:encoded><![CDATA[<p data-pm-slice="1 1 []">Hello, after a long time without using it, I've started up my MK3S printer again. The issue is that I noticed some areas of the first layer of the printed part appeared slightly burnt. So, I decided to run a test by printing just a single layer covering the entire bed. As you can see in the picture, it looks like there might be a section of the bed that's hotter than the rest.</p><p>Could someone help me out and let me know if this is something that can be easily fixed, or if replacing the heated bed is the only solution?</p><p>Thanks!</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/d6990cc6-img_2840-scaled.jpeg"><img class="alignnone size-medium wp-image-174856" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/d6990cc6-img_2840-600x500.jpeg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/problem-with-heated-bed/#post-739346</guid>
