Printing issue with Simplify3D 4.0.0
MBX Teknik
(@mbx-teknik)
Hi! I'm having this printing issue with Simplify3D together with my newly assembled MK3;
The shorter diagonal are fine but the longer the diagonal line are, the longer distance the line is missing, as you can see on the image:
Here is a link to the gcode of this print:
https://drive.google.com/file/d/1gIBdCyXqlbflSwKaZ5x6qJYcFzpC8kq9/view?usp=sharing
(I have printed the same STL, sliced with Slic3r PE with no prolems at all...)
Anyone of you knowing what is causing this issue?
Thank you!
/Martin
Posted : 10/06/2018 11:32 pm
MacRaven
(@macraven)
Re: Printing issue with Simplify3D 4.0.0
at a first glance I see you have LA enabled but you print in PET and have set K30 (PLA/ABS) for PET you would need K45 as stated in the Start Gcode field.
This might cause your Problem.
But i had no time to test it, like said just a first look.
Dirk
Posted : 12/06/2018 9:16 pm
