Printer won't print
I'm at a little bit of a loss here. The printer won't even print. I can't even get through a calibration. Printer runs fine for about 10% of it, then the motor starts clicking. I don't know enough about the system to diagnose this. Any help is appreciated.
Clicking usually means that movement is blocked and the motor is missing steps. This can be a clogged or seized bearing, a displaced component or a worn guide.
I would bring forward the next maintenance session in case it's something simple:
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072
https://help.prusa3d.com/guide/maintenance-tips_23200
- and if the problem persists isolate the problem and come back here - which motor is clicking?
RE: Printer won't print
It was a calibration issue. An adjustment to the Z axis level seemed to do the trick. How do you delete a post?
Thank you for the input. I'll keep it in mind, but I want to try another test print before going further, atm.
